What clutch is good for altezza????
AE111_SEG
1,024
180
3,163
Putra Heights
use back the original clutch.... unless there was a issue with it?
Greytezza
1,130
68
1,648
Truly Asia
i already use original clucth...can i use trd clucth for more kick....
It is not advisable to use a Toda flywheel with a TRD clutch plate. They might not fit together.
It is better to use a TODA flywheel with a set of TODA clutch and cover plate.
Likewise for the TRD flywheel.
1JZtezza
371
42
Bro! What do you want???? You can use a twin-plate racing clutch also but its just not practical or try metallic race clutch and cover plate and good luck to you in traffic jam!!!
green
326
25
3,028
kl
errr what does he mean by more kick??? :confused:
kindly explain. putting in a better racing clutch or better clutch will NOT make your car go faster. only makes ur right foot feels numb n sore on traffic congestions(unless original)
faster way is to put in a 4.7 final drive!!! fuiyo u will get instant acceleration
good luck
Syamsul Anuar
From Facebook
13
melaka
www.facebook.com
good luck
good idea...but how about top speed???
i agree with all of u...maybe use original clucth its better....
green
326
25
3,028
kl
of course with such a high final drive, u will definately lose some top speed crusing. but again wat top speed are u talking about? crusing at 180km/h? 200? 220? 240?
stock altezza to reach 180km/h with 4.7 is ok, but probably will stress ur engine n gearbox due to high rpm. 200km also ok...u can try hahahah
so u see, there is NO shortcut, u gain in some area u lose in another area. plus how often u can zoom up to 200 on our normal roads? even highways are packed with cars
unless u put in a 1j/2j then u gain in ALL areas. but its pricey and if the workshop is crappy...ur car is a goner.
good luck
Hello. I just bought my gen2 cps last week. But I heard alot of noise from the air-cond panel, steering, door and the accelerator got abit low sensitive.. somemore... there are some noise from dashboard when i rev it. Are there same with other gen2 cps ? mine one is auto transmission.
