Urgent help!
kemm
13
Sri D'sara
www.sync-rnd.com
Sifu-sifu, I'm driving Eg8 (1992) with b16a (1995). My car last night cannot start, like go no fuel. I check the CEL and gives me code 1,3,7,9. I checked thru and 1: O2 Sensor, 3: MAP Sensor, 7: TPS, 9: CYP Cylinder.
I don't know which is which and where to start to solve this. can anybody give picture or clue?
My car was parked in a public car park and I need to get to it fast by today.
amdfaisal
4,743
20
Bawah jembatan
i now nuts about B16A but normally if your distributor is not working you cannot start your car. happened to a fren before.
anyway there are many things that may cause failure to start
1 - fuel delivery failure (fuel pump, no fuel, etc)
2 - electrical problem (distributor, spark plug)
3 - ECU kong
4 - etc, etc
If your TPS sensor kong you should be able to start your car but the engine will run super rich to avoid problems
If O2 sensor kong should be able to start your car but the engine will run in open-loop
If MAP sensor gone - me dono what the consequences really are
If the cylinder sensor gone - me dono what the consequences really are
- from a person who does not have a B16A
kemm
13
Sri D'sara
www.sync-rnd.com
Cool! I went to the car just now with a mechanic.. he said the distributor kong already no spark. so, thank you very much guys. really appreciate it! :_:
if you don't mind, can anyone guide me on where can I find more info to repair/troubleshoot CEL 1,3,7,9 I posted earlier. Tried to search but very hard to get. :angel_smile:
amdfaisal
4,743
20
Bawah jembatan
normally you can check urself if the distributor is at fault... with at least one friend to help le...
pull out the plug cables with the plugs attached at try to start... if no spark... then most probably distributor.
if you rode a bike before maybe you know this method...
kemm
13
Sri D'sara
www.sync-rnd.com
ya lah. my fren just use a screw driver, poke into the cable end that attached to the plug and put the exposed part of the screw driver near metal parts. Less work I see coz u don't have to get extra tools to take the plug out, eh?
amdfaisal
4,743
20
Bawah jembatan
don't really remember what my fren paid for his recond B16A distributor. maybe you can call LHS to know the price of a brand new distributor. if got money go for new one better kot...
shiroitenshi
3,677
170
Here in Kelantan is 450 for a recond unit at the local chop shops.. 380 considered okay already what... but if you're hardworking enough to go bargain hunting.. maybe can get cheaper.
As for the CEL codes.. I just googled it up because I'm too lazy to write one up. This one includes the procedures and the codes to CEL checking.
http://www.c-speedracing.com/faq.php
Man.. google is your best friend.. :P
kemm
13
Sri D'sara
www.sync-rnd.com
Cool.. thanks shiroitenshi Cool nick btw :shades_smile: . I got the part getting the codes. But what I really I want to know is how to troubleshoot these codes? Maybe I have some ideas on CEL 1, 3 and 7 (maybe need a digital multimeter and check current & if defective change the sensors lo, am I correct?) but what about the CEL 9, CYP Cylinder? what is it?
kemm
13
Sri D'sara
www.sync-rnd.com
heh.. I've been thinking about that since last night! maybe I'm gonna carry one spare for unexpected events like these, or could help a friend in need as well. this is the 2nd time happen within 4 year. I guess ditributor will broke every 2 years, eh?
J101
1,304
malaysia
well you can check for resistance on that wiring. then check continuity in the wires
most times i think a cel 9 isn't improperly shielded wires or loose connections at the ECU. if its a hardware problem it should be TDC sensor inside the distributor.
you can contact POJI_EG9 for help, check out this thread
http://www.zerotohundred.com/newforums/showthread.php?t=123653&page=2
kemm said:
any idea on how to repair CEL#9?
shiroitenshi
3,677
170
hattech-v said:
it will fail at anytime. even new coil oso can be kong at any time.
Yup.. agree with this.. better carry a spare in the trunk and the wrench just in case if you're travelling long distances.. not that you cannot find a distributor in a chopshop anywhere across malaysia.. but more like.. you will get 'cekik darah' prices.. hahaha.
