TURBOSMART Comp-Gate 40mm WasteGate
Revolutionary Locking Ring
Comp-Gate’s unique Locking Ring provides easy access to the the actuator, allowing for quick spring changes. The new actuator housing design allowed us to significantly reduce the height of the Comp-Gate40. It is up to 25% smaller than other wastegates in our range.
Higher Flow, Smaller size
New, compact body profile offers superior flow, compact dimensions and exellent heat handling characteristics. Measuring only 99mm, the Comp-Gate40 fits easily into space-restricted engine bays, and provides better access once mounted. One-piece, coated stainless steel valve and an optimal flow through the body provide superior performance and reliability.
Unique Rotating Cap
Comp-Gate’s clever cap design, together with the locking ring allow for the cap orientation to be indexed in 12 different positions, making this one of the most versatile external gates on the market. Changing the cap is a simple procedure of loosening the locking ring (using the tool provided with the Comp-Gate) and rotating the cap into the desired position.
Interested please contact us @ [email protected]
We are located in Bandar Sunway beside Sunway College.Behind Works Engineering.
012-2206117 (Denny)
016-9973300 (MATT)
Unique Rotating Cap
012-2206117 (Denny)
016-9973300 (MATT)
