Tufoil question.....
pillage2001
260
Hie, let's say I try tufoil and don't find it t obe as impressive as it is, can I just do a regular oil change after 5000km and not flush my engine?? WOuld there be any negative effects on it like sludge built up or what not?
aircooled
265
yes, you should be able to. I don't see why not. If you really want to flush your engine, my suggestion is to do it with normal engine oil and NOT any flushing liquid. Most of these liquid actually flush out the remaining oil and i would say quite harmful to your seals.
pillage2001
260
Originally posted by FocalPoint@Mar 22 2005, 17:43
Tufoil doesn't cause sludge formation. An overused engine oil does.
[snapback]830838[/snapback]​
So I can stop using it all together without having any probs?? Sounds goo.d Prolly will give it a try.
Sifu .......
Need advise . There is 1 mechanic told me that ECU 4g91 sohc and it's gear box can used for 4g93 . Is this can be done .????? :
Coz , i'm planning to transplant 4g93 to my 1.5 wira .
Is this combination is compatible ????
:D :D :D :D :D
