Trumpet for Blacktop 4-Throttle
AndrewMIVEC
1,503
Hi, anybody out there can machine (aluminium) trumpets for the Toyota Blacktop 4 throttle?
Hole diameter start at 49mm and grow to around 70mm at 75mm height... or any other custom dimensions??
Rgds,
Andrew
tamok
155
Hai Andrew
I got stanlessteel trompet for black top
give u'r pn no...I send the pic for u....
JINEIL2EN
Over 10,000 RPM!
15,317
525
3,213
Island Of Pearl
team99ers.2.forumer.com
refer to ur requirement, theres got a few basic spec u can follow & if u ask for more, then u hav to calculated the cubic & ur needs...
tamok
155
jdm from halfcut..some member said the long neck good for STV n the short neck for BTV''
sorry if wrong...
JINEIL2EN
Over 10,000 RPM!
15,317
525
3,213
Island Of Pearl
u'r right... but not all..
not to says so...
its all depends on wat u wan 7 how u wish ur engine can be... mayb can b more easy, short & fat is more to higher rev which no bother the low end toq at all, while tall/slim 1, is more to 'Balance'...
difren cam will have difren setup...
tamok
155
you all right...must be right set-up..tambah itu and tambah ini if not sengok-sengok.he hee
Veloc
3,234
991
Sabah
not to says so...
Bro.. Care to explain? Got such thing as trumpet tuned for low-end torque? I thought once we go trumpet, we can forget about low end already? Can we still get low-end torque if use trumpet?
And... lets say we use long and slim ones, which is for low-end torque, is it better than the low end torque for stock filter/open pod/CAI?
Thank you...
SYeNi69
402
47
TTDI KL
of course ... matter of fact ... changing to CAI/exhaust also it would be proper if u do tuning ... then only u can fully utilise it :)
Hi guys, i was looking at my car just now and i noticed there's a crack at the front panel of the body frame (the part near those radiators / behind the bumper). There's a crack and i'm worried my whole front part will fall apart.
Could you guys recommend what i should do and any workshop is good in repairing or fixing this.
