Toyota Altezza Marketplace Links - Parts & Others
RS200
Sep 5, 2010
18
5
503
Altezza 3SGE Engine with Auto GearBox Rm1800
Altezza Power Steering Pump
Altezza Air Cond Pump
Altezza Alternator (Starter)
Altezza Front n Rear Caliper n Rotor Set . rm500
Altezza 4.1 FD Differential .
Altezza 4 x pcs 17" Original Sport Rim with center cap rm800
JZA80 Supra Front and rear calipers , rotor set rm2200
Brembo Evo 8 Front and Rear calipers with rotor . rm3200 .
JZX100 Aftermarket Japan Turbo Manifolds rm1200
JZX100 Cusco Front Under 3 point member brace rm300
JZX100 Cusco Rear Sway Bar rm250
JZX100 Cusco Front Adjustable Upper Arm rm500 (Booking) 11/11/13
Sard original R2D2 Blow Off Valve . 99% like new used less than 1000km . rm300 .
HKS Actuator .
All Stuff in Good and Running Conditions .
Thank you . Updated 11/11/13
Intrested Pls Call: 013-2373772
Or Whatsapp : 019-2963772
AE101-Wong
4,448
113
SXE10 G1 6MT CKD half cut NEW ARRIVAL
http://www.zerotohundred.com/newfor...sxe10-g1-6mt-ckd-half-cut.html#post1064096885
SXE10 altezza TOM's lower engine bar NEW ARRIVAL
http://www.zerotohundred.com/newfor...zza-toms-lower-engine-bar.html#post1064096888
SXE10 rear trunk mat NEW ARRIVAL
http://www.zerotohundred.com/newfor...7815-sxe10-rear-trunk-mat.html#post1064096879
TRD semi bucket seat for SXE10 NEW ARRIVAL
http://www.zerotohundred.com/newfor...emi-bucket-seat-for-sxe10.html#post1064096880
SXE10 altezza rear trunk netting NEW ARRIVAL
http://www.zerotohundred.com/newfor...ltezza-rear-trunk-netting.html#post1064096882
SXE10 NEO bumper with oem grille n fog lamp NEW ARRIVAL
http://www.zerotohundred.com/newfor...ith-oem-grille-n-fog-lamp.html#post1064096881
SXE10 rear bumper with lips NEW ARRIVAL
http://www.zerotohundred.com/newfor...e10-rear-bumper-with-lips.html#post1064096884
SXE10 yellow eye fog lamp NEW ARRIVAL
http://www.zerotohundred.com/newfor...sxe10-yellow-eye-fog-lamp.html#post1064096886
SXE10 oem fog lamp NEW ARRIVAL
http://www.zerotohundred.com/newfor...417823-sxe10-oem-fog-lamp.html#post1064096887
SXE10 rear carbon fiber register plate cover NEW ARRIVAL
http://www.zerotohundred.com/newfor...iber-register-plate-cover.html#post1064096889
SXE10 rear oem spoiler NEW ARRIVAL
http://www.zerotohundred.com/newfor...26-sxe10-rear-oem-spoiler.html#post1064096890
SXE10 4.556 TRD ratio with ATS 2.0 way LSD NEW ARRIVAL
http://www.zerotohundred.com/newfor...atio-with-ats-2-0-way-lsd.html#post1064096871
18" work VS sport rim with tire NEW ARRIVAL
http://www.zerotohundred.com/newfor...rk-vs-sport-rim-with-tire.html#post1064096872
SXE10 altezza rear axle drive shaft NEW ARRIVAL
http://www.zerotohundred.com/newfor...zza-rear-axle-drive-shaft.html#post1064096873
SXE10 altezza front lower arm with ball joint NEW ARRIVAL
http://www.zerotohundred.com/newfor...lower-arm-with-ball-joint.html#post1064096874
SXE10 altezza upper arm with ball joint NEW ARRIVAL
http://www.zerotohundred.com/newfor...upper-arm-with-ball-joint.html#post1064096875
SXE10 altezza lower arm with bush NEW ARRIVAL
http://www.zerotohundred.com/newfor...tezza-lower-arm-will-bush.html#post1064096876
AE101-Wong
4,448
113
SXE10 GPS navigator without monitor NEW ARRIVAL
http://www.zerotohundred.com/newfor...navigator-without-monitor.html#post1064104127
SXE10 buddy club brack box re-chip ecu NEW ARRIVAL
http://www.zerotohundred.com/newfor...lub-brack-box-re-chip-ecu.html#post1064104128
TRD brand new brake pad for SXE10 NEW ARRIVAL
http://www.zerotohundred.com/newfor...d-new-brake-pad-for-sxe10.html#post1064104129
SXE10 cusco zero 1 hi lo soft hard adjustable absorber NEW ARRIVAL
http://www.zerotohundred.com/newfor...-hard-adjustable-absorber.html#post1064104130
SXE10 tein type CS hi lo soft hard adjutable absorber NEW ARRIVAL
http://www.zerotohundred.com/newfor...t-hard-adjutable-absorber.html#post1064104131
AE101-Wong
4,448
113
i'm planning to get a autogauge BF RPM meter for my iswara. There's few stupid question i would like to ask...
Is the reading visible clearly during day? Cause i drive my car mostly when the sun is up...
And any iswara"rians" around... can the meter be fitted just in front of the original RPM? i mean like just in front of the plastic visor for the stock meters...
thanks people
