The mechanic in the workshop uses a flat head screwdriver to "dig" the power window set on my car till it leaves a small scratch there.
Any proper method to extract the power window set so it doesn't damage it?
As I said, if u know where is the clip, than u don't need to dig. For my car, I open the door panel & put my hand inside to push out the power window control. but I open too many times, now a bit lose.
BS, you mean the windows make noise went they're down or up during door closing?
I encounter 'not so solid' sound when I close my car door with the window down.
Daniel,
I m facing the same issue with you. I usually park my car under sunlight when I go office. So I usually wind down the window to let the heat escape. I think it's common for our car.
All sifu here help! My car running too rich i think, the fc is 0.25 per KM, that is rm 50 for 200km! Is it normal or its unnormal? O2 sensor problem?
Wira 1.5 gli auto 1999
Here are this list of mods i did:
1. 4-2-1 exractor ---> de-cat(replace with bullet) ----> S-flow muffler
2. oversize throttle body
3. And the rest small mod i think no effect the fc one eg. air filter and etc etc
