Taller 4th or 5th gear for Evo 4/5 GB
nikolaiski
88
36
Hey all
Is is actually possible to rebuild an Ev0 4 or 5 GB with a taller 4th and 5th gear inside? Take note i do not want to change the final drive or my 1st-3rd gear will be affected. Reason is, going to use the car to go JB-Penang, maybe thailand more than once in it's lifetime, and KL-Singapore every month.
If can, from which gb do the taller synchros come from?
Thanks guys!!!
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
if it was me....to choose specific gearbox ratio...
that would be taller 1st,2nd,3rd...with closer 4th-5th....slightly longer final drive...
this means u can pull 1,2,3 gear a little bit longer hence no need to change the gear frequently in town traffic.....and still without bad effect of too-long 4th-5th gear....(u can take example of 4speed autobox where 3rd and 4th ratio was placed longer which sacrifice highspeed acceleration)
nikolaiski
88
36
hmm...but won't the pickup and lower speed drag suffer? Or can make up for that with boost? :D :D :D lol
my main aim is to enable the car (4g63T) to have good drag/track capabilities from 1st-4th gear, with the facility of an overdrive 5th to cruise comfortably between 160-200km/h..with the rpm around 4000 rpm at 180 km/h in 5th gear. Possible?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
nope..it wont suffer,,,,instead of the turbo didnt have enuf time to spool already need gearchange...now u still accelerating with fullboost and full power.....(good for late spooling turbo setup)
nikolaiski
88
36
hmmm..ok...so going on this...how easy is it to obtain a taller final drive for a Evo 4 GB? lol..apparently the terbalik evo gb parts very hard to come by :((
