4G93,4throttle
StealthSpeed
7
selangor/KL
Hello all sifus..i got question on how to fit a 4throttle intake into my 4g93..currently im using Emanage piggy,i heard that i have to change to standalone ecu if i wanted to fit a 4throtle on my 4g93?im really tight on budget:hmmmm2: please give me advice on what should i do guys.. :adore:
xtremeleo
3,247
464
5,183
u dont need a standalone for dat,an emanage is more den enuff to takd,d job on. although,i wudnt suggest going d 4throttle way,get a bigger tb and intake instead
kayour
326
41
itb...good for hirev
sluggish at low
and idling suck...hahahaa
xtremeleo
3,247
464
5,183
if the setting isnt correct,ull lose power across the revv,not adviseable.ive seen a 4g93 gained 20 horses when changing from itb to single throttle+larger intake. dat doesnt necessary means d later setup produced more power,but it confirmed d itb setup decreased power. it wasnt set up properly imo
fastclubman
469
Itb, it's all about setting it up properly. Having a plenum helps w the low end power. Been using itb setup for over 3 years now, and definitely a lot more powerful than previous single throttle setup. Idling improves ESP when running big cams and response a lot better!
xtremeleo
3,247
464
5,183
yes,u need d intake plenum,most dont even bother to fit dat in for d so called suction sound
The Marketplace Top Posts
Guys, I have some problem, after some investigations:
- usually when temperature passes half, radiator fan will on and once the temp is slightly below half, it stops
- problem is, sometimes even after half, the fan is still not moving causing the temperature raised high (almost red bar)
- i thought the fan broken, tried to knock the motor (suggestion from a friend), still not working
- but, when I turn the AC on, both fans (radiator & AC) are on now. Meaning, my radiator fan is working! It...
