SURBO (Air-Suction-Turbo)
brings your engine to the RPM red line with just 1/2 throttle! Not only will you have more speed and fun, as you won't have to depress the accelerator as much as before, you'll also save fuel and reduce emissions. Put a Surbo on, and give yourself the freedom to sprint all day!
What is SURBO and how it's work
The Surbo (air suction-turbo), fitted air-tightly along the air intake, uses engine back pressure to generate cross air jets and therefore a vortex to produce higher air compression, resulting in high-revving power
In conclusion, the Surbo is more of an air pull-through device, to make the air pass through the engine rapidly to enable rpm to be gained quickly, with an edge at very high rpm if not rpm-limited. This is in contrast to the high air pressure input devices like turbochargers or superchargers, which use air pressure buildups at the inlet side.
Advantage of SURBO
Most of Twin Surbo user is PROTON cars..
Price as below includes installation:
Get your car fitted with SURBO via our nearest area agent:
Visit https://www.facebook.com/
Car already fitted with Surbo:
Mercedes-Benz E200
Proton Satria Neo
Proton Persona
Advantage of SURBO
- Significant gains in torque 15% (Single Surbo) - 20% (Twin Surbo)
- Driving satisfaction
- Improve fuel consumption (less acceleretor pressed)
- Higher speed & better acceleration
- Reduction of emission and CO2
- Assist on overtaking, hill climbing and overcomes engine loads like a airconditioner
- Fits to almost car with air intake hose size 3 inches and below
- Installation plug & play concept, save your car warranty
- Lifetime warranty, UK patented
- Transferability from car to car
- NO maintenance required
- Single SURBO - RM 170
- Twin SURBO - RM 340 (MOST RECOMMENDED)
- Surbo Kmn 012-9384919 - Kemaman, Dungun & Kuantan
- Mie Surbo Pahang 019-965520 - Bentong, Temerloh, Jerantut, Bera, Jengka
- Taufek Surbo JB 013-7297598 - Johor Bahru
- Hisham Surbo Utara 017-4633779 - Alor Setar
- Surbo Melaka 019-6854829 - Melaka
- Hadi 019-9152664 - Damansara Damai
- Syed Irwan 012-9650882 - Kota Bharu
- Surbo Malaysia 016-9981296 - Wangsa Maju, Ampang, Kuala Selangor
Mercedes-Benz E200
Proton Satria Neo
Proton Persona
