That to me sounds like the car may have gone into "limp mode" or "safe mode" would check the fuel pump/o2 sensor or maybe as someone said it has a big airleak
Try running diagnostic as if its electrical it may have logged a code
or any wire cut off inside...from my experience
wire to plug coil, near the connector cut off..and cause the problem intermittenly
my solution..just by passed the connector
the only way to solve this problem is to check one by one.. sometime is a big issue such as ECU short circuit but sometime it could be simple as loose connector..
got problem.... power windows driver seat...stuck!!! jam at the midle...huh....how much its cost....????.....some said its windows gear can not operate oredi.....
:sad_smile: :sad_smile: any rekomen workshop arrr ( KL area )
