Sudden Under Power
resh9999
109
10
While traveling at 140km/ph, car was under power n was vibrating . Its like 'semput' when pressing the pedal. Slow down was fine ,press the pedal /floored to max ,rpm doesn't goes high . Could this cause by steeper motor .
Sent from my UItra 4 using Tapatalk
ixeo
4,788
3,080
KL, Malaysia
i kena before on another car, vacuum hose leak.
pac_jb
131
14
518
Check your maf sensor connector ,
lsm1991
1,469
185
PJ
chis can be so many things..... stepper motor, well i cant say for sure BUT, i guess the stepper would cause more issues when cold, once warmed up, u can unplug the bugger and barely feel any dif (speaking assuming the ac is off)
resh9999
109
10
Plug less then 4mth. Went to Ah Wah , he change Airlow sensor. But yesterday same problem while traveling to ipoh . When this happens there is a sound like lose chain , then I let go off the pedal n go at slow speed. Then if I speed up ,it be OK for while then happen again
leinnz
333
57
3,028
i kena once. due to clogged Air intake
resh9999
109
10
Fuel pump 5.mth old. Yesterday traveling back from Ipoh at constant 160 n 140 no problem at all .
biao
348
24
518
perak / ipoh
Gearbox problem?
resh9999
109
10
Went back to Ah Wah . He said must check all sensor to check which part losing pressure. Gear Box is fine . As far as I know its a hardcore gearbox .
biao
348
24
518
perak / ipoh
your fuel pump just change not longer? try to take it out and assembly again. maybe the hose connection leaking inside the tank.
stutzedward
3,416
561
Ah Wah is the best person to resolve your problem. Is it resolved yet? If he can't, I really don't know who can fix the problem.
I was asked by my friend to assist him with painting his brake calipers as the original metal finish just dun look good enough. Being an avid DIY-er and semi-pro detailer, I agreed to give a helping hand and lend him my tools as well.
Owner removing the wheels of his car.
When working with the car up, always use an A-Stand to ensure maximum safety...
