Strengthen Engine Mounting or Engine Damper
dfx16
107
6
I had broke the engine mounting for the 3rd times within 2 yrs as i had FI an NA ride
A workshop suggested change new engine mounting and add on a engine damper
B workshop suggested strengthen the engine mounting via silicon
What's the Pro and Con?
Any suggestion?
Thks for any input
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
if done both and ur engine still vibrates alot at high rpm, its time to invest in full engine blueprint and balancing...
Bump: if done both and ur engine still vibrates alot at high rpm, its time to invest in full engine blueprint and balancing...
JINEIL2EN
Over 10,000 RPM!
15,317
525
3,213
Island Of Pearl
team99ers.2.forumer.com
at that time, the engine won't vbrate, but the whole car is....:proud:
JackWaiKit
262
5
www.friendster.com
I m using evo mounting for front & rear only,left & right use ori Mits...but vibrate during low rpm...
until my dashboard screw also loosen...
But i have also changed many time of Mits. mounting since it broken...
Nothing will cover the both...!!!:banghead:
popout
366
can i tumpang ask 1 question ?? wat is engine damper izzit like mounting?? cuz i see alot of engine damper like aerospeed... but duno wat is the function??
popout
366
So izzit every car come with this thing original or just an additional thing
do u guys know where to get auto current cut off device????
try to find in pasar road liaw but did't find it.
this device is ued as this way.....
the input of the amp is radom,sometimes very high and sometimes very low.
then i have an electronic robot which only work properly in certain amp and above.let say 3amp and above this robot will work fine.
so now i would like to conect an auto current cut off thing in btw the inout and the robot.when the input is lower than 3 amp then...
