what kind of modification can be done on a stock turbine?how much will it cost?whats the side effect?
what mods can be done if i want to be able to pull long?Joeker said:Ken,
I not turbo god like SDF,
Heres wat I know.
First of all, you must decide wat you want from the turbo.
You want response or hi boost or can pull long, etc.
Each requirement have their own mods.
PS : Opppsss, I accidentally clicked edit, I actually wanted to click reply, Sorry.
is there any down side by porting the housing.. e.g. gain more in pulling but loose more in....?Joeker said:Louder spool?
DOn't use Air filter. :D
Pull longer?
If not mistaken, change/port to larger exhuast housing without touching the compressor side.
any idea where can do this and what the price?Joeker said:Faster response and can boost higher?
I think you should change or port the compressor housing and change to larger impallers (trim wheel).
DO not change the stock exhaust housing and turbine.
