Stock alarm+immobilizer, turbo timer
wfc31
138
wfc31.fotopic.net
i am having ???? regarding how the stock alarm+aftermarket immobilizer work together with turbo timer?
let say now i have stock alarm and immobilzaer in my car, as normal i arm & disarm when leaving & entering car.
but when i install a turbo timer for my turbo car, when i leave the car and arm the alarm while the engine still running during the timer count down, will the immobilzer cut off the enginer?
trex92
756
5,018
It depends on how u wire ur immobilizer and turbo timer. If you wire them parallel the turbo timer would still function even though the immobilizer kicks in. If you were to wire them in a series, ie from immobilizer to turbo timer, then ur turbo timer would not function. Just a matter of how the wiring is done. I presume that ur immobilizer is just a basic starter motor immobilizer right? Not those that immobilize the ECU too. I guess even with ECU immobilizer, it can still be done, but the wiring would be more tricky.
et_all
12
WFC31 :- My car got stock alarm and stock immobolizer...I also got turbo timer even my car dont have turbo :)
Well, the man that install timer to my car quite expert....My immobolizer activate once my timer finish countdown....Need to put relay...
U can go one shop... beside N1 in sunway....Ask Ah loo....I satisfied with his work...I drive vios
