stering shacking
ler
175
KL/SEL
dude kindly have tis problem
when on accleration nothing happen but when i hit a brake whether slow or hard my stering shacking ...what coz a problem ...i already check
1. adsober = good
2. diskbrake plate = good
3. engine mounting = good
pls gif me some advised guys...
e861
36
perhaps you should go for tyre balancing and allignment. see if that solves the
problem. do update us.
ler
175
KL/SEL
already do a balancing +alignment +chamber+ on wheel balancing at famous tyre shop near p.ramlee house jln genting klang...
tcng
10
bro check ur tyre..by the way wat car u drive?if kelisa, den change the stock tyre..
front tyre or rear tyre condition will make ur car steering shaking when u slow down..it happen to me..even balacing it also not use..
siangmh
199
when idling will ur steering still "shake"? (or do u mean vibrates?)
ler
175
KL/SEL
When acceleration no problem only when braking.my steering will do turn left and right but not so strong to make my car slight to road sight...pls any advised
ler
175
KL/SEL
where is the shop i quite fimiliar wit zoo negara area
deftons
422
if the disc plate is in good shape as claimed by u .. then plz check your brake pad .. ;)
kelisa6009
Over 10,000 RPM!
17,144
40
Penang Kia
i also driving kelisa...recently i face this problem...i am now using MYvi brake disc...when i step on the brake pedal ...my steering will shake...i have check the brake hose, aligment and also change my tyre..still the problem is there..one of the mech told me i need to skim my brake disc...i already done that last 4 month before i install this MYVI brake to my car..so izzit brake pad will effect the steering vibrate?
Hi SIFUs at ZerotoHundred, I am new to machine polishing and recently I had try out the Meguairs D300 compound with their microfiber finishing disk and got the result below. The result is good but I think it could been better as I feel like there is light haze from the compound.
Before:
After:
From the picture I hope...
