steering problem
Mivec77
when i drive through bad road surface my front steering tend to pull left and right.. It's still happen even after i did my wheel alignment.. pls help me out.. it started after i've changed my front brake to a mivec ones.. i'm using satria..
JohnIsler
12
i think it is your front brake is dragging. try to drive ur car for 15 mins, then touch the rim for each front wheel, n diagnose the temperature of each. my 2 cents. :P
puffcurry
156
Ampang,Kuala Lu
profiles.yahoo.com
:D its the steering rack bushes...the one in the middle..proton's wears out after 1 year of use..its nuthing really..but if u want to get it change, a normal will set u back around rm90...i manage to haggle the price till rm60 coz i changed my tyres,alignment,chamber at the workshop that day..takes bout 20minutes..
Hi guys.. would like to hear opinion from all of you like in the title above..
what's pros n cons if do the wide (widening) body (fender) in long-term?
effects to the drive shaft .. absorber.. absorber link.. bearing.. ball join..lower arm.. tulang anjing.. or etc..etc..etc..?
besides it's gorgeous looks.. steady..
because i heard/read alot of bad comments about wide-body (fender) in long-term..
because I intend to do a 2-inch fender widening to my waja,as soon as...
