Steering Judder Problem for Evo
ifanonline
56
6
1,508
Hi Guys,
Wishing all MLOC members a Happy New Year!
Opening the new year thread with a slight car problem. During high speed brakes, my evo streering started to judder quite badly but not on a normal driving. I am not sure what causes this, it is either the brake disc/rotors or the brake pads. I have just recently change my worn out brembo rotors to project u on the front and yet to change the rear rotors.
Would like to ask some advice and solutions on this problem.
Thanks.:driver:
lanevo6
1,204
40
jb-melaka
Hi Guys,
Thanks.:driver:
if rotors are new and assuming also your pad are new give some time to beddin.
after that still have you may want to swap your rims to confirm
3rd or lastly could be your ball joint.
Just from experience...when i bought my car the ori rim judder badly at high speed. after changing to CE28NF ok no problem. 7 years later same problem and found that my ball joint gave way
ifanonline
56
6
1,508
hmm...thanks bro for sharing the info. I have only changed the front rotors to project u, will check whether it is because the rims or ball joint. Not sure whether it is a common problem in Evos...
lanevo6
1,204
40
jb-melaka
i would same common problem if rotors are stock for all evo's. If after market rotors should not have this problem. So you may want to look into others like bushing. How old is your evo?
ifanonline
56
6
1,508
it is a 10 year all evo..talking about the bushing, i think i have already changed mine...
lanevo6
1,204
40
jb-melaka
10 years might need to check your ball joint.
ok at least can rule out the bushing. :smokin:
^pomen_GTR^
7,000 RPM
7,514
1,690
The Mines
check balljoint+ all lower arm bushes as well
