I've seen a lot of people rebuilding a car for racing purpose or for on the road will go through this process.. especially more than 10 years car.. Whats the Ocassion & Advantage? How much the cost? Where can be done? thanks.. :D :D :D
1. Why spot/seam weld the car body? To make the body stronger. A stronger body helps alot in improving car's handling, which is very critical in racing.
2. Cost? Over RM1000
3. Street cars rarely go for spot/seam welding coz the process is very hard (u have to remove car paint and strip off everything out of ur car (engine/interior/everything) leaving only bare chassis, after welding u have to repaint & put back ur car components).
well..as for me..i did a simple spot weld for my everyday car. i did the A, B and C pillars of the car where i noticed the flex. also some coners around it. So i striped the interior of my car (do it urself so it would be cheaper) and got it welded at a spray shop... cost me about rm80. then i bought a oil based paint (for rm15) and painted it myself. i noticed a significant amout of difference afterthat..
just ask ur friend to sit in the passenger seat and when ur taking a hard right corner ask him to place his finger in between the window frame and the body of the car (where the door rubber is).. you can actually feel the window frame opening up at the top slightly (old cars..new cars not too much). mine was pretty bad that wind started coming in but after i did the welding.. no wind!! :) i'm driving a 23yr old car...
I'll agree with your opinion Olskool.. I've no intention to convert my car for track uce.. Its my everyday car.. since I'm converting the engine so thats why thought to do some simple spot weld.. maybe engine bay area and rear axl area (its FR car).. is it enough to feel the different or is there any other places need to be weld too.. thanks..
no probs dude...btw..i have a friend that bought a mag from japan recently and i saw (in the pics and ask him to translate) how they strenghten their car bodys the cheap and budget way. they only use those 1/2cm steel L brackets and place at the necessary area. so simple!!! then they use the cars for drift... :lol: :lol:
Stengthening adds weight....
Actually it's much easier to get a roll cage fabricated for a street car then seam/ spot welding......
Very tedious process.....
Problem with roll cages is that it's illegal if spotted by our datuks and uncles in blue, white and blue... :lol:
spot and seam weld does increase chassis rigidity, but up to street levels. for track and autokhanas, a roll cage is a must.
will try polyurethane fill into chassis once i got the time to look for the person. Heard from newspapers this fella can do it for less than 1K...how much i dunno.
I have a L6 turbo Kancil, the change done in early 2011. The car does not perform as well as it should, the job being done in Melaka. I don't know whether the mechanic who did the work did it properly. Does anyone know a reliable and honest turbo mechanic in the Klang Valley?
