Hi bro,
I played the 4AGE about 5 year already.
1. I found out 4AGE until now still didn't got people kacut the gear ratio like Honda and mitsu car. Even i searching arround the web, also can't found it. Only saw people change the final drive only. Are it is the dead point of the 4AGE?
2. After install high cam, why always got heard the knocking sound? Are it is timing need to advance? But already did it, it seem more ok. But it still. Then i solved out with using 7M injector 315cc injector + Fuel Regulator. But still heard of knocking, just a small litter bit only. When idling, the engine run very smooth (i will upload the clip soon). Are high cam is like that? currently i used TRD 272 * 7.1 lift in and Ex, and even Toda spring valve.
