satria 1.3-1.6 suspension, what parts i need?
140dB
393
johor
hi people,
i have satria 1.3
i have eibach 1.6 spring
what parts do i need to put it all together?
i have a feeling the springs are of different diameter, probably, spring seats/abs, absorber mounting have to change?
i was thinking of kyb abs.....do they have adjustables for stock 1.6 springs?
tia,
140dB
Yong_5290
3,637
49
Klang
hotmail.com
i got ohlins adjustable soft hard to fit wit 1.6/1.8 spring for sale
btw...u need the top mount also..
140dB
393
johor
gee thanks....but a bit over my budget. plus as u stated..its hcut cond..
i hear kyb rs lowers the vehicle too
Kelis
162
Penang
Hi 140db, I think u need to change the absorber mounts n the absorbers too in order for u to fit in those springs.
lby
209
Johor Bahru
www.lby.fotopic.net
Hi 140db, if i not wrong, u have to get the 1.6 absorbers and the top mouting plate. 1.6 spring is bigger than the 1.3 spring.
anyone know is it able to put GSR suspension (whole set) into wira 1.3? need to mod?
galantorian7116
1,147
The front suspension ie absorber and spring for Satria 1.3 and 1.6 are definitely different. You cannot install a 1.6 spring onto a 1.3 front absorber, and vice versa.
In order to fit in the 1.6 spring to your 1.3 car, you will have to replace the 1.3 absorber with the 1.6 absorber. And not forgeting the front top mount for 1.6 model. The rear suspension is compatible for both 1.3 and 1.6 model.
yswong67
10
so for the whole set of suspension 1.6 satria will cost about how much? (approximately)
140dB
393
johor
galantorian7116 said:
Should be below RM 1100.00 if you take after market sports absorbers and spring, like GAB product.
izzit so cheap for gab adj springs and abs?
but i oledi got springs...
i need adj abs..
hotbits adj setup will put me back rm1200 like that
full set kyb rs maybe 500-600 plus, and not adjustable
how much is gab?
galantorian7116
1,147
Guys, i said : "Should be below RM 1100.00 if you take after market sports absorbers and spring, like GAB product."
I never mention the price for GAB Adjustable suspension lar....., please don't get me wrong. The price is true for GAB Sports Absorber and GAB Lowered Spring.
140dB
393
johor
so i misinterpreted. sorry
and how much do i expect to part for a set of adjustable gabs which match my eibach 1.6 springs?
galantorian7116
1,147
Well, you can't use sports spring with a Hilo kit. The hilo adjustable suspension uses different type of spring - called Coilover Spring. The size and shape of the coilover spring is totally different from your sports springs.
The first impression of this new 2008 Mini Clubman 5 doors is it has a longer wheelbase. The 3.1 inches extra provides that much more capacity compare to its counterparts, also allowing easy loading capabilities to the owner.
Though pricing has yet to be announced, officials say buyers can opt for the turbocharged or the regular 1.6L engine. The NA version cranks 120hp...
