Range Rover 5-liter Supercharged now available here
Dinesh
770
1,700
1,593
Land Rover has just introduced the 2011 Range Rover 5-liter Petrol Supercharged intot he Malaysian market with enhancements made to the Terrain Response as well as exterior cosmetic touches.<b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b>
The 5-liter V8, developed in-house by the Land Rover engineers, pushes out 510hp and 625Nm of torque. It’s mated to a ZF six-speed auto that provides for some seamless shifts and a century sprint time of 6.2-seconds.
The Terrain Response system now comes with Hill Start Assist (HSA) and Gradient Acceleration Control (GAC). In the Range Rover, the HSA feature is permanently active and so does not require to be switched on when needed. The GAC works to provide cover on extreme gradients if the Hill Descent Control is not in use. It does this by applying the brakes to limit the acceleration according to the throttle position when traversing a gradient. It also works when the car is moving backwards in reverse gear.
On the outside, the range-topping Range Rover now gets a set of 20-inch alloy wheels at all four corners as well as a Nobel mesh grille for the front and side. As you step inside, you’ll notice the illuminated treadplates on the front doors. Creature comforts include a Harman Kardon Logic 7 sound system with 14 speakers throughout the cabin.
If you’re thinking of having one parked in your driveway, you’ll have to shell out RM798,888 if you live in the Peninsular while those that call Borneo home will need to fork out a little more at RM802,388. Both prices are on the road but excluding insurance.
My car is currently a 4G92 1.6 SOHC.
Im looking in to upgrading this bugger a little to give a bit more kick.
Is it possible to change my 4G92 1.6 SOHC top block to a 4G92 DOHC 1.6 MIVEC top block, Reuse my bottom block and gearbox, change the TB, intake manifold, ECU, exhaust manifold, and injectors to MIVEC ones?
Btw, how much does a MIVEC 1.6 top block with all other items (ECU, TB, manifolds, etc) cost nowadays?
