Hye guys,
I've got couple of questions here about camshaft, the story is i'm planning to do regrind camshaft at matspeed, i have two set of cams n its from 4G91 and 4G93, for 4G91 cams the higher degree matspeed can regrind is 272, and for 4G93 cams can go up to 288 degree..
i'm planning to go at 272 since my car still use for on the road spec.. situation is if i regrind 4G91 cams to 272 compare than 93 cams to 272, is there will be any different? like lift, loop, and how bout performance?
and to all sifu wat is the best degree cams for otr car? 272 or 288? afraid if i go to 288 cams nanti susah nak bawak coz still using aircond.. i'm using gsr engine, td05 20g, CA18 piston n conrod, adjustable campulley, tb evo, wgate, emanage piggyback,
which one the best cam setup for my engine?
advise n comment is much appreciated... tq, tq.
