Question about rear lower arm bar
Jun 12, 2014
30
i driving satria and i want to install lower arm bar, does it affect car alignment ?
do i need to re-alignment my car after me install ?
do it have any side effect ?
mADmAN
1,840
547
to answer ur question.... no
yest must do alignment back...
but no point installing it...because that 2 point where the bar mounted was the strongest point in car chassis...
boyzone
2,669
Is no point to install this bar.
Advise to put in anti-roll bar or rear top strut bar instead of this bar.
I also notice that ur car do not have 4 points lower arm bar at the front.
Save some money and go for it... help a lot on the handling.:driver:
RENESIS VIII
7,063
950
Ipoh
Good question. My car have that too but people told me that it doesn't really do anything.
gunnerzz
Jul 3, 2014
2,109
695
Melaka
Yes u must redo the allignment as the holding screw will effect the camber setting if not mistaken.
Effect?
Not much really which is why its cheap. I wanted to remove mine and use it as a defensive weapon.
IMHO,
u should install the front strut, front lower, rear ARB, rear upper, room bar and be done with it.
If u still come back and tell me u are not satisfied, i will bang u on with the UR bar i just removed earlier...hahaha.
Seriously, i believe those bar are enough. Unless u are a track kaki.
Looks nice for the guy behind to see it......:rofl:
---------- Post added at 02:47 PM ---------- 6 hour anti-bump limit - Previous post was at 02:46 PM ----------
Yup, that screw is for rear camber adjustment...:smokin:
RENESIS VIII
7,063
950
Ipoh
Looks dumb after hearing all of you saying it is like useless. But I saw before many Wira with the similar bar with mine. According to my mother, this lower arm bar came along like one set when the strut bar is purchased. That was long time ago, I'm still in kindergarten back then. :rofl:
If you look at the solid metal that the bar is attached too, it not that soft to flex, right?:rolleyes:
Just want to do some survey, coz currently i'm using 4G63T engine. How much the current market price on 4G63T from Vr4 Cylone to Evo3 range. The reason i;m asking because after JPJ put new rule that engine price drop..so is it a good time to buy one for a spare..:regular_smile: maybe not complete part if small part price drop also ok to save it as sparepart
