Problem with engine
Aug 21, 2010
4
Miri
Hello frenz,
I have some problem with my car engine. :hmmmm:
It will jerk/turn off while still moving when I press the clutch to shift from high gear to low gear and when slow down at trafic light. It happen quite frequent unless if I keep on accelerating the engine. This only happen when I turn on the aircond.
Fyi, I'm using engine Silvertop 20V that fix into toyota AE111.
Appreciate your help/idea on how to solve this problem.
Thank you.
D7zul
2,697
848
Shah Alam
try checking the intake hose between the throttle plenum & the AFM sensor.. mayb its broken (got holes)
i have similar problem with the same engine.. just change the hose & u'll solve the problem..
Perhaps the best power ( or torque ) gain from the use of Tufoil happen in these 2 car models. Owners have reported power increases that surpassed their imaginations or even our own comprehensions.
Must be all the tired bearings inside the engine waking up and turning effortlessly now. All engine bearings thrive on good lubrication and more if they are slippery like Tufoil.
We would like to hear from our zth friends about their experiences if they happen to own cars like these and using...
