This also happen meh?
Any comments about the welding issue? That's plain scary.i checked in proton FB, it happen when the car hit the divider at his right side.....then came to a stop. so damage at fender, bumper, lower arm, tire n absorber....at 1st i thought it just fall off..scary... but if its an accident then not so bad....
that is plasma spot weld, done by robot, ugly yes, dangerous noAny comments about the welding issue? That's plain scary.
I see. I will take some time tomorrow to have a look at the car.that is plasma spot weld, done by robot, ugly yes, dangerous no
Preve ground clearance is quite high. It's very possible that only the lower/underside of the bumper came into direct contact with the divider while the wheel/suspension took full impact from the collision. Hence, the bumper stays intact.What the hell ?
do you notice the front bumper didnt even get a scratch ??? then the wheel just dislocated like that ?
It is quite clear cut case that the classic got problem leh...
Just like above saying.. the divider not even like 1 feet of what...
This is going to be a very very bad negative news for proton... ( or maybe it is just the turbo boosted too high...haha )
**** FOR PROTON TO PROVE NEW PREVE IS FINE - 2 WHEEL STUN PLS ****:stupid::stupid:
pls... malaysians are not kind to kia either...Preve ground clearance is quite high. It's very possible that only the lower/underside of the bumper came into direct contact with the divider while the wheel/suspension took full impact from the collision. Hence, the bumper stays intact.
Also, from the low resolution pic, how can you be sure there's not even a scratch on the bumper?
Nobody knows what really happened, but one thing is for sure. If the car in the pic was a Forte or a Civic, all the comments posted here would be very different.
