Hi there everyone, i m facing a huge problem with my sound system.
Here is how sound system runs, Pioneer mp3 player, to a 4 Channel Amp, From Amp 2 Channel for front 2way speaker - bridge the 3 & 4 channel to a sub-woofer. Rear Speaker direct from player.
Actually there was no problem at all for the first year, but after i change the amp a few times, now got problem even if i use back the same amp that i had use before to test.
Here is the problem, there was noise from the speaker when i start my enjin, if off then no noise. And i cant connect the front speaker to the amp at all, only woofer can, coz if i set the amp to LPF then ok, but HPF then there was huge noise like the speaker broken, i even tested with a denoiser but it doesnt help at all.
Now for temp, i had to connect the front and rear speaker to the player, only sub-woofer to the amp. Although its still can be use, but when i start my enjine there was also noise while i was driving, i had to open the vol higher to cover up that annoying noise.
Please help everyone, i very headache and feedup with that noise.............:emoticon_U:
