Performance Gauges: Wideband Air Fuel Ratio Kits
DDT
Brand New Set
Wideband Air Fuel Ratio kits:
*With reasonable & affordable price, just rm720.
*Come with 1year warranty for the gauge display unit.
*Sensor is consumable item & no warranty apply.
*Free gift for every purchase of the Wideband Air Fuel Ratio Kits.
Please contact:
012-3223583 (Franky Long) Klang Valley
016-3181129 (Oliver Yong) Klang Valley
012-9013452 (Jeff Tarca) Pantai Timur
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
*With reasonable & affordable price, just rm780.
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Brand New Set
Please contact:
DDT
Depo Racing is proud to offer the most innovative Wideband Air/Fuel Ratio Gauge. Air/Fuel Ratio data is important for tuning as it helps achieve optimum power and safety. Unlike other gauges on the market Depo Racing Wideband is fully digital and large OLED numbers for an easy read. The Wideband is compatible with all fuel types and uses Bosch Power LSU 4.9.
Depo Racing UEGO - wideband air fuel gauge utilizes the Bosch LSU 4.9 sensor which is superior to the LSU 4.2 sensors. One major difference between the LSU 4.9 and LSU 4.2 is the LSU 4.9 uses the reference pumping-current, while the LSU 4.2 uses the reference air. This allows the LSU 4.9 to get rid of the reference air, and therefore remove the biggest failure mode; as a result the LSU 4.9 has a long life and maintains accuracy throughout the life of the sensor
Most aftermarket wideband controllers still use the LSU 4.2, mainly for low cost reasons. Bosch sells the LSU 4.2 to the aftermarket at a much lower price than the LSU 4.9, plus, many of the controllers are not able to adapt to the new LSU 4.9 as the technology is different. In fact, most all OEM who use Bosch sensors are using the LSU 4.9.
The Depo Racing wideband air fuel gauges feature a 0-5v output for closed-loop feedback when pairing with a standalone ECU or Piggyback. Depo Racing Wideband measures at 52mm with an OLED display that a 3 color sweep from Red, Yellow to Green. The Depo Racing Wideband using the Bosch LSU 4.9 is able to have accuracy and utilizes a 3 digit display.
Please contact:
DDT
Please contact:
DDT
Please contact:
DDT
Please contact:
need u guys help urgently, i just bought a control panel and something look like a relay or resistance.its from lancer. only this two item, i heard can just plug n play to existing satria dashboard. if can install, which button cannot be use from the control panel? how much is the cost to install it? recommend me a mechanic pls. my phone num 013-3973088.
