Opti-Coat™Pro : Toyota Vellfire G's Edition
s1tl
1,237
1,019
713
Ipoh/KL
We have with us today a rather special Toyota Vellfire, unlike the common ones you see on the road, this is the G's Edition. With a sleek looking upgrade on the body, red calipers, black wheels, and that murdered out sinister feeling when you look at the car in the front. Check out what we did to the car fresh from the recon car dealership.
Upon arrival, the car is already looking mighty glossy and wet look. That is because its black and black is forever deceiving to an untrained eye.
As we do the routine walk around, we squat down and spot the sun beaming into a tonne of swirl damages right at the side of the door handle.
At the top left corner of the car we spotted some clear coat unevenness that we could not sort out just with polishing.
Paint surface condition on the other hand is not that great.
Swirl condition covers most of the glossy black panels
Including some tight spots as well.
Looks shiny but swirls everywhere, who would have expected this?
Wheels and Tyres were covered in rust powder and brake dust.
Major difference after cleaning and Opti-Coat Pro coverage. See the caliper is more "Vibrant" now.
So a quick before paint correction under Phone flash.
Before paint correction under LED torch
Before paint restoration we can visibly spot swirls and light watermark stains.
More visible watermark stains.
Right before the final pass.
Finishing reflection.
The side panels are in similar condition after the paint correction.
And Finally for an even more drastic gloss and wet mirror finish after Opti-Coat™Pro protection and coverage over the entire car. We present to you, a Brand New Toyota Vellfire, better than show room condition.
I own an old Proton Iswara manual 1.5. At times, I have problem starting the engine. It gives a tick sound but it doesn't work. I need to turn the key a few times to get it running. My car has already installed with a starter relay long time ago. In fact, I have just replaced a new relay. But the problem still persists.
I read somewhere that by giving a knock on the starter could probably fix the problem; that if the starter has no problem. Could someone tell me where exactly where is the...
