Occasinal stalling/switching off at idle/low speed
mdss
71
9
508
uk
Hi
Looking for a little help identifying a problem
Very very occasionally when coming to a stop or after stopping and selecting reverse from drive or park the car will switch off/stall.
I have had it plugged into a MUT tester(genuine Mitsubishi tester) and there were no faults. Has anyone experienced this type of thing and if so what is the likely cause. I thought maybe a dirty idle speed control valve but that's just a guess. I thought I would ask you guys with more knowledge than me.
Thanks in advance for any help given.
mdss
71
9
508
uk
can you clean it or is it the case that you can buy a new one?
I will try and clean it over the weekend if you advise this may work.
Thanks bud your a legend
Not sure same as VR one, but mine need to change. Mine the engine was not dying but cannot control idling with air con cuts in and out. Mine also common problem, change once, after 2 years or so, problem came back again.....:banghead:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
my problem last time on my satria actually due to leaking vaccum from valve cover breather pipe (leaks at oil filling cap actually)
but i still retain 2ficd..... 1 for cold start and another one for a/c :biggrin:
as for ts....can try servicing back or atleast check the ISC gear...it can be replaced with little cost instead of replacing whole throttle body
mdss
71
9
508
uk
Thanks guys, I just watched a video on youtube on how to clean it so I think I will have a go on Saturday. Mine is not terrible to be honest once a week it will stall, I get no irregularities with idling so hope its just some dirt and a clean will sort it out.
Hey all,
Wonderin' if anyone knows wat i can use to make a replica setup as a turbo timer but with noy turbo as my accord doesnt have turbo nor am i considering to get turbo. Some of you might think this is stupid or dumb idea but people have der own styles.
Cheers
