**NISSAN, TOMEI,NISMO,HKS, BILLION Performance Parts**
kaminari
1,031
43
Taiping
Having below parts for sell,
Stock Location : USJ, Selangor
Inquiry: [email protected]
(No telephone contact given as i`m not at Malaysia) any inquiry please email me, will
give further details/price )
NEW parts:
1) TODA Evo 4-9 1.5mm Metal Headgasket
2) N1 RB20/25/26 Oil pump
3) Nissan Skyline R33/R34 Fan Belts (A/C, Pwr Steering & Alternator)
4) PITWORK RB25/26 Timing Tensioner
5) PITWORK RB25/26 Timing Idler
6) Nissan Silvia SR20DET OEM Piston Ring sets
7) Nissan Primera P11 SR20VE OEM Piston Ring Sets
8) HKS Platinum Iridium Racing Spark plugs RB26/25 M Series , Heat No.7
9) HKS 4AG Oil pump Up Pressure kit
10) NISMO Thermostat SR/RB **RB Thermostat SOLD**
11) SR20DET 7 Layer metal Exhaust Gasket
12) SR20DET OEM Rocker Cover Seal
13) S15 ORC Clutch Line
14) TOMEI SR20DET 1.5mm & RB25DET 1.2mm , 1.5mm Metal Headgasket
15) BNR34 OEM Boost Solenoid Sensor **SOLD**
16) BILLION Thermostat 1JZ, 4AG 16V 20V (Slv/Blktop)
17) PITWORK RB20/25/26 Timing Belt
18) Nissan Sentra SR16VE OEM Headgasket
19) R33 ORC Clutch Line
20) OEM RB25/26 IN EX Valve Seals
21) BNR34 Throttle Position Sensor (TPS)
22) OEM RB26 BNR32 Crankshaft Seals Front & Rear
23) BNR34 Clutch Release Bearing PULL Type
24) S14-15 Clutch Release Bearing
25) BNR34 MFD Replacement Screen Kouki & Zenki **ZENKI last PC**
Regards,
Kaminari Performance
miriguy
887
20
i need prices for the following;
560cc injectors with fuel rail
tomei 270 degress camshafts
nismo 2-way lsd
exedy twin plate clutch kit
hicas stopper
master cylinder pump
clutch bearing
all for rb25det ecr33
thanks
i have a satria 1.3 carburetor. the engine can be rev up to 6k right? is it good or bad to do that? sometimes while revving at 5k rpm, i can feel the gear box shaking. Is it some problem or what?
If i drive at normal speed with normal gear, its smooth.
