Need some advice - Proton Persona - How to install grounding cables 7 points
gotbandwith
22
Hi all...
im noob here and need some advice. recently just purchase a 7 point grounding kits (kinda cheap since same price normally can get 5 points only). so need some advice on how to DIY install it.
can anyone give some comments / suggestion. if got pics / diagram where it should be hook-up will be better too.
thanks. :biggrin::biggrin::biggrin:
jeffayn
621
62
3,028
Klang
for the persona,
you can hooked up the body, the are near plugs, the alternators ....
these are the common place to hooked up... but do not hook at the wrong place like the fuse box or a diff polar wiring..
Hi guys...im driving a toyota ae111 or known as SEG with engine 4afe stock.
recently i found out that my car is hard to start when its hot...
like i part at convenient store to buy stuff,then when wanna back home,hard to start...
i already change the distributor,new plug cable and spark plug edi...
and somemore run diagnos to check got sensor broken anot...
and the problem is still there...can some1 tell me what is the problem?
when its hard to start, i can smell petrol smell... :(
i...
