need help with radiator
scoupe
1,087
37
5,148
shah alam
hey guys i need help getting a radiator. curentlly my radiator is not good enough, it a 2 core one and the longest that would fit my engine bay. of late it leaks often so i think its time to get a new one. i was thinking of getting a aluminum 2 core radiator. where can i get it? or is it possible to change the core to aluminum? my current cores are rusted badlly. pls advice..
praetorian
236
aluminium radiators can look at Fidelity Radcore. they might be able to help you,
but the heat dissipation of an alu rad is not much better than copper,
weight savings will be negligble for a road car, but the cost will be higher
if your rad is rusting, try to use a better radiator fluid, and flush out the block 1st, or else it'll happen again
scoupe
1,087
37
5,148
shah alam
so would it be better i get a normal 3 core radiator? where is fidelity radcore located? how are their pricing? anywhere else i can custom a radiator?
scoupe
1,087
37
5,148
shah alam
hyundai scoupe. the thing is i have transplanted an engine into the car. so i need something that really can do the job as this engine seems to be really hot. how can i contact KOYORAD
for what car bro....search for KOYORAD...nice
Jack_Hon
255
!!!need help about custom car approval
all sifu out there or any 1 experiance
do i need JPJ approval after i fix some custom made body kits(car look different then original e.g. kenari mod to accord) to use it on the road???:Not_Impressed:
