can anyone pls help me, i have done twice top overhall hall...for my vitara 1.6, 8 valve 3 door....when i drive my car just after 1 week after change all...quarter is lost of the black oil...im fustrated...pls help need advice
Last time my vitara only a little bit leaking and the oil was so slow to also need general overhaul. After overhaul, no leaking at all. May be your vitara need general overhaul. May be the leak is at the flywheel there that u cant see.
Hi guys,
Lately having problem with my car battery. The battery having parasitic drain. Send to wire man also cannot locate the drain. Off alarm, take out HU etc. still draining. If don't drive for 3 days the battery will be drained until cannot crank the car. If use daily then it is okay.
My car is manual and have jumper cables, means can push start or jump start but then when alone both also useless.
Then made research and finally ordered a Multi Function Jump Starter. Sort of a Power...
