me jus bought the rim..haihs... regrets.. if i change to gas type absorber.. can the problem slove? actually i dunno which part the rim kena... :frown:white_bird said:okay... my experience.. it's juz bcoz ur rims r TOO WIDE.. i used to use 15x6.5j.. it juz cant help.. even though changed to adjustable abs.. still kena fender.. so the conclusion is.. change ur rims to 6j n below..
u sure shocks wont solve my problem? cos my car is very new ler... ju 4 months.. n i didnt change lowered spring...or i change to gas type absorber will settle this?jeffayn said:when the tyres is hitting the guard. it only can be that the spring is not in a good condition ... you may have constantly carr a lot of people or u had change to lowering spring ..
shocks will not solve this problem for you ...
i driven kenari b4jeffayn said:when the tyres is hitting the guard. it only can be that the spring is not in a good condition ... you may have constantly carr a lot of people or u had change to lowering spring ..
if u at setapak.wangsa maju..find me la...i help u see see n look look..FOC...one ice coke enuf..ehehelittlegiz said:me jus bought the rim..haihs... regrets.. if i change to gas type absorber.. can the problem slove? actually i dunno which part the rim kena... :frown:
huakenny said:i driven kenari b4
ur tyre is 165 or 175 wide???
im using 175/45/R15 tyre in 15 x 6.5 rim...lowered spring with Monroe Sensation or sensatrac (forgot) absorbers.....
wil hit mudguard only when speeding wit full-loaded....when hit some holes la...if normal road is ok....
Pm me la....i at setapak areas one oweslittlegiz said:im using 175/50/R15 tyre in 15 x 6.5 rim... ori spring n absorber.. actually if i'm alone or wit one passenger.. won't hit geh.. if full-loaded... die lor.. hav to drive like tortise..haha
how much u bought those monroe n wat spring u use ler? i was planning to change gas type abs n lowered spring...but scare... hiah..
eh.. bro.. give me ur num ber.. maybe i'm free i com look for u.. then give me some idea bout it... ok?
hey bro.. for me turning is no problem.. n i oledi ketuk the steel plate... but still got sound when got passenger behind.. haihs...stroker_kit said:why not try to ketuk the fender from the inside...
btw, is the problem only when u turn left and the rear right rim got sound? or the rim got sound even while driving straight..
if the sounds comes only when making a left turn, then it should be the steel plate ..the one on top of the rear spring..u'll need to grind that steel plate...all kenari are like this...
