need help!ignition problem
AccordRacing
kepong
my ride is accord95,when morning start or cool whether start,when i turn the key,its cought...cought...cought...like struggle n finally its start,i have check the battery,its in good condition,alternater working well also,starter no problem..when u have warm up the car,then turn off n on agian its just like normal...watz happen now?just hard to start it again when put it several time or at nite& morning time...sifu pls help
change your spark plugs. Check the heat rating of the plugs to see whether if appropriate for ur car or not.
besides spark plug, if u having idling problem...try locate the ICV and clean it with carb cleaner, assume ur car engine is EFi.
cheers
A thread every 60 seconds
