Need Advice - 4G93 engine - Port polist or Balancing or Cams
MadCow76
229
Need Advice - 4G93 engine - Port polish or Balancing or Cams
Hi all,
I own a 2002 year Wira with a 4G93P engine and I've just recently converted the Siemens ECU to a Satria Gti ECU #2468. So far I've done the entire exhaust system; mivec extractor, custom downpipe, 2" piping and muffler. Not forgetting the drop in K&N air filter.
I'm planning to squeeze more power out from the engine's potential and this leads me to my questions.
Which of the following brings out more power; Port Polish or Engine Balancing? According to my mech, the cost for either one is almost the same give and take a few hundred ringgit la. What would you sifus recommend?
I am also considering changing Cams but don't quite like the up and down idling sound. I like the idling to still sound like normal so no one knows my engine is modded. What kinda cams would all you sifus recommend as well?
Appreciate all your inputs and recommendations.
Thanks in advance, cheers...
cooljas
523
MadCow76 said:
Hi all,
MadCow76,
The best time to do engine balancing is when u do a engine rebuilt. I would suggest u go for Port n Polish first but before u do any Port n Polish go dyno ur engine after Port n Polish go dyno again see how many hp u gain or hp u lose, everyone will think tat Port n Polish will gain hp but wrong way of port n polish will make u lose a lot of hp!
If u put in a pair of high cams, ur idling will not go up and down if the cams setting is correct....
Cheers
g88
3,081
54
get a set of Matspeed cam with J5 management...
MadCow76
229
cooljas said:
MadCow76,
Cheers
Hi cooljas,
Thanks for your explanation. I get what you say about about port and polish, that's why I need to find a reputable mech for this. Oh and I also plan to dyno my car soon just to see how many hp gain from changing ECU and the total exhaust system.
What is an engine rebuild?
Do you mean that if I put a set high cams the idling will not go up and down? Then how come I hear some peoples car who's got high cams their idling is up and down esp at traffic lights.
Cheers...
MadCow76
229
Hi g88,
Thanks bro. I keep hearing about Matspeed cams, are they better than speedworks or powerzone cams? How much would they cost?
Cheers...
khoyos
2,632
156
5,163
Shah Alam
if i were u, i'd change the cams first. relatively easier and faster to complete compared to taking out engine head or the whole engine.
when u get more cash to do up engine, then u can port the head based on the characteristics of the cams, and do engine balancing based on the cams also...
if u dont want lumpy idle, then whats the point of changing cams? cams that dont have lumpy idle, usually wont extract much power...
to me, cams are the best way to force out the hidden horses in our engine...
20vturbo
755
9
Sarawak
www.club4ag.com
can tumpang ask also?
4g91 block can masuk 4g93 head or not? coz sumtimes i see ppl said "for 4g9x series" that means part interchangeble? can exedy 3 puck from 4g93 masuk 4g91?
khoyos
2,632
156
5,163
Shah Alam
4g91 block can masuk 4g93 head or not? -yes
can exedy 3 puck from 4g93 masuk 4g91? -can if u use 4g93 flywheel. flywheel size different but interchangeble
cooljas
523
MadCow76 said:
Hi cooljas,
Cheers...
If u want a reputable PnP specialise person i can recommend u, most of his job done is proven in sepang drag machine,pm me for his number if u want!
An engine rebuild is u dismantle every of ur engine parts n replace the wear n tear parts!That is y i advice u to do engine balancing when u rebuild ur engine!
The idling will not go up n down very obvious if the cam setting is correct...juz tat when u on the air cond the engine cant idles but u can install in a FICD and tat will solve the problem!
U can opt to go for a high cam first but prepare at least rm3k for the process,a pair of cams will cost u roughly rm1800, a pair of cam pulley will cost u at least rm300-400, after installing high cam u need to rechip or piggyback ur ecu which cost around rm1k for the management and also an adjustable fuel regulator will cost u at least rm300.....
Y i advice u to go for PnP first is because we do things step by step...feel the power of PnP first then after u put in the cam u feel wat sort of power is the cams r pushing out!
All depends on ur budget!Juz my 2cents point of view
Cheers
keong_GSR
1,009
try p n p first,if want better respond,go for 93T head,d diameter of d exhaust n intake port r bigger then stock na 93p...
put cams n d indling not smooth is normal lar... u got to live with it. i suggest u go for cams gear b4 putting d race cam...
1st of all, why u dun go for piggy back direct? it's no point to change old version ecu or wiring... emanage cost 1.3~1.5k plus install n setting...
MadCow76
229
Hi khoyos, cooljas and Keong_GSR,
Thanks for all your input guys. I guess I will try PnP first since it's cheaper than the cams. I also agree on doing it step by step to feel the power increase on each step I go.
cooljas, will PM you soon for the PnP contact. I didn't know you have to change so many things just because we change cams. I always thought that need to change the adjustable cam pulleys only.
Keong_GSR, my original ECU was a Siemens ECU, that's why I changed to a Gti ECU so that I can do more mods. I am also planning on installing an SMT-Advance piggyback unit soon, but that'll happen when I get the cams in.
What's a good brand of cams and where can I get it? Also, how much ah?
jaydee
334
Subang Jaya
The idling won't go up and down one, I bet you heard that few years back... this is year 2006.. everybody knows to tune properly..
Now without high cams I can make the Idling go up and down for u also.. :)
Bro, change cams then the old cams pass to me k? hehe...
MadCow76
229
Hahaha...I don't see it happening that soon yet though...
kob3bryant
484
wat if u get a 92mivec head to put on?heard the feedback r not too bad man!the cost should be within ur budget
MadCow76
229
That's one option for the future la. How much does it cost ya? Heard it's expensive la...
deacon
Senior master debater
1,165
30
About 3k depends on how you do the mod. However this 3k does not include mivec ecu and harness, if you go this route a full piggy back like E manage or unichip or something to that effect would be best, unless you have money for a standalone ecu.
If you buy the full half cut then about 6k give or take 1k, depends on seller.
kob3bryant
484
try to search for the block only loh,the internal part r important.ecu wise get aftermarket to fine tune the combustion efficiency.but the mivec ecu is really important for the mivec to kick in.i heard some other said can make the mivec kick in w/o the original mivec ecu,but the menthod i dun know.prepared rm 4k is better.make sure u get a good mechanic to do that.becoz when i used 4g92p b4,i modded it to twincam by using 93 head,the performance is not too bad,actually quite happy with tat but tat's leakage issue.a little bit,yes really a little bit of engine oil came out from the gasket seal.u cannot notice the head is oily.
tis is the photo of my previous engine.
MadCow76
229
deacon, MIVEC is still so expensive even though just the head without ECU and wiring.
kob3bryant, nice engine bro. In the future I hope merge my engine with a MIVEC in the future la...now is still too expensive.
Thanks for the link btw, he's selling it cheap la but I can't afford it now 'sigh'...
kob3bryant
484
then u better think twice b4 u wan to upgrade further.whether it is hybrid engine,n/a or turbo-charged.if u mod n/a,u pay more to get XXX hp and u spend lesser in the t/charged way but with the same gaining
I found out my car battery always losing its charge after I leave it overnight. I am sure i did not accidently left the headlight on. Also I just change the battery 2 weeks ago. I think my Gen 2 got a parasitic battery drain. This is my first DIY, so please leave a comment.
I got below procedure from (http://www.wikihow.com/Find-a-Parasitic-Battery-Drain). Add info on what I did for my Gen 2.
Introduction
When your car battery goes dead overnight, usually either the battery is at...
