NA timer on Neo campro?
neohadri
200
34
mine is H-Line ,
have installed it 3years ago, installer add relay to get it to work,
timer working without any problem, but i'not sure whether there's any bad effect to immoblizer
neohadri
200
34
ohh... thinking to install ornot.. how muchu installed and what brand last time? :)
why do want to install it anyway? i regret installing it, because i don't like the idea of messing with car's
wiring & electronic's,:banghead:
btw mine is apex'i turbo timer ( the fake rm70 one) & cost to install is rm30
holysniper
159
518
N/A
Oh.. actually I also don't like the idea of messing with the wirings too.. but sometimes hard driving ju:driver:s before parking then I hate to jus shut off direct and spent like e timing sitting there cooling down abit..
Any problem with the fake one? Got volt, af, o2 readings?
neohadri
200
34
no problem so far (touch wood)
if u can find timer with correct harness for neo, then there's no issues about messing with electronic, because it should be plug & play
mine only have timer & volt meter only, i opt not to have AF reading & O2 reading because the fella who install it said he will have to tap to ECU to get the reading & i'm not comfortable with that:eek:
If I retard the CAM timing for let say 4 degrees, do I need to advance the ignition timing for 4 degrees? Please enlighten.
