My Waja is getting weaker n weaker!!!!
ivanlim84
36
My Waja is getting weaker n weaker....no strength..need to step on the accelarator fully then only it will pick up..die la...i dunno wut s wrong..I jes service my car 1 month ago..izzit coz of the engine oil?? man...now jes move the car can d..dun care bout pick up or speed..so guys, when u c waja moving slow n no pick up n there s a young chinese guy driving..plz be patient...hehe...wut m i suppose to do man??
edwin_lcw
1,242
Setapak
no go tuning issit ? got change your gearbox oil anot (for auto)? spark plugs condition ? haih ........ too many to say but the most is tuning lo ...... no tuning just maintainence the car will last long but without the power ...... maintainence n tuning the car will last long with power lo
ivanlim84
36
my waja s auto..gearbox oil not yet change..not yet reach the mileage yet..i very long time din go tuning lo..will it be expensive r if go tuning?? i thought coz i change the cheap engine oil then become like this...izzit coz of the engine oil??
HKNP
266
u are using thicker oil?? what u mean cheaper oil?
check your spark plug... maybe yours is running 3 out of 4 leh.. meaning 1 of the spark plug kong alreadi.
ivanlim84
36
i dunno wut type of oil izzit wor...i noe it s cheap la..how to check whether all the spark plug working or not?? take out everyone n try 1 by 1 r??
edwin_lcw
1,242
Setapak
first engine oil doesn't affect any performance lost lo ...... the diff on the quality lo but not like u say gettting weaker n weaker ..... gear oil change on every 30K km ..... spark plugs is one of the factor ...... does it jerk on every gear change ?..... tuning wise i dunno lo ..... didn`t bring my dad waja go tuning b4 ....... never had this problem using Q8 onli ...... sometime i have to say this ..... buy proton car is talking bout luck ...... got luck car no problem no luck your car is like hell .....
gohkokeng
2,443
4
edwin_lcw quite agrees with u
my friend LMST the left power windows button spoilt 1 time......change new button about RM20-RM25 (forgot) then after few months spoilt again.....fed up then no fix liao......left windows non-function.......lucky not right one....
karlok18
32
Malaysia
i got this problem b4... but i am using manual tranmission... after i change my cluth then ok le... ur auto may gear problem @@
edwin_lcw
1,242
Setapak
mostly waja problem is always auto gear oil .... coz they dunno the rates ..... its 3OK km .... if u kong your auto gear ...... pls go for new manual cars ..... n dun think of replacing one ......
ivanlim84
36
i jes change my plugs..i m thinking that s the plug problem..it s better a bit now but still weak though..the shop mechanics try to cheat me..he check all my stuffs like air filter, engine oil, timing belt.....do u think air filter will cause my car to be weaker..i dun think so..i wont go that shop again..well, at least my car s a bit better..my car din jerk evrytime change gear..everything s ok..i think must be the transmission oil..it s bout time d the mileage..left around 3k then need to change d..if i continue driving then will it be ok r??
ivanlim84
36
evo engine lo..die lo..better buy 1 whole new car..hehe...i never trust proton stuffs anymore man..
edwin_lcw
1,242
Setapak
air filter sure la .... not more than 30 bucks ..... long time didn`t change then must change ....... no air go in where can make optimum combustion in your combustion chamber
hi new to mivec .. just put it in and need some help
seem to be having some problems with mivec after awhile.
Engine light comes on.. blinking once.. then stays on solid .. idling became rough at start up before warming up.. loss of power.. huge backfires can be heard when slowing down and no mivec activation
can sumone help me rectify this problem ?
can it be:
-a faulty map sensor?
-dirty mivec solenoid? - how do you remove and clean it?
-loose connectors?- which wire mainly to...
