MSD Blaster 2 in 4g15 help!
saga611
15
Hi Guys,
Im sort of interested in having this MSD blaster 2 coil installed in my proton saga. however after some research i found that some mods need to be done on the distributor cap as well as disengaging the stock coil.. etc...
currently my 4g15 is set up wif twin dcoes, 4g91 pistons with balanced internals and stock cams.
can anybody shed some light on this?, will the coil benefit me or can i do without it?
Thanks and Warm Regards,
peterlm
97
8
508
Penang
MSD and any other ignition coil add-ons are expensive and neds to modufy the stock distributor cap.
Heard of Fire Storm Ignition Enhancer? I just installed mine 2 days ago and sharing with others in thsi forum.
Pick up faster and smoother. No need top cut any wire or drill any holes. The spark from the plugs are much much stronger and completely burns the air fuel mixture squeezing more power from the same amount of fuel burnt.
Works the same way as the MSD but much much cheaper and easier to fix and remove.
Cheers.
Hi there i need some help regarding speedometer...i would like to ask can we actually adjust our speedometer mileage ??? I just bought a new speedometer the mileage reading is 50,000 my previous reading was already 150,000...so is there any way i can adjust it...some friends told me just use needle & tick it will do...will this make it broken ??? didn't dare to try....help appreciated thank you
