Mosconi AS 200.4
Stereo Power RMS @ 4 Ohm 4x200W
Stereo Power RMS @ 2 Ohm 4x320W
Bridge Power RMS @ 4 Ohm 2x640W
Bridge Power RMS @ 2 Ohm 2x950W
Input Sensitivity Range 0.2 / 5V
High Pass Filter Range (switchable) 20 / 175Hz
High Pass Filter Slope 12dB
Low Pass Filter Range (switchable) 50 / 300Hz
Low Pass Filter Slope 12dB
Band Pass Filter Available
Internal Fuse 1x150A
Dimensions 590mm x 200mm x 50mm
Finishing Silver
RM 2800 ( 11 months old, 2 weeks Personal warranty)
Sell due to car sold. Lovely POWERFUL 4 channel ever made.
Audio System F2-450 (Open Box Condition)
2 x 234 watts at 4 ohms
1 × 718 watt channel 1 + 2 bridged at 4 ohms
718 watts total power
RM 1100 (NEW). Sell due to project give up!
MY LOST your GAIN (I have 2 units)
Peerless XLS 12" with Rubber Solid Woodbox (Condition, 2 days)
Peerless 830500 XLS 12" Subwoofer
By introducing the new Extra Long Stroke (XLS) series, Peerless has pushed the performance limits for subwoofers. Whether it's for an active home theatre subwoofer or for audiophile applications, XLS subwoofers will fulfill every demand for deep clean bass reproduction. The design emphasis has been put in achieving extreme deep bass, long time reliability, high power handling, and very low-distortion. All XLS subwoofers feature large full roll rubber surrounds, nomex fiber impregnated cones and aluminum shorting rings for low distortion. Peerless has also designed matching "passive radiators" for use with their active subwoofers to enhance their performance. In the recommended 1.48 cu. ft. enclosure with the 12" XLS 425 Passive Radiator, the resulting bass response extends to an F3 of 20 Hz! * Power handling: 300 watts RMS/425 watts max * Voice coil diameter: 2" * Voice coil inductance: 4.2 mH * Nominal Impedance: 4 ohms * DC resistance: 3.5 ohms * Frequency response: 18.1-500 Hz * Fs: 18.1 Hz * SPL: 90.6 dB 2.83V/1m * Vas: 4.92 cu. ft. * Qms: 3.7 * Qes: .21 * Qts: .20 * Xmax: 12.5mm * Net weight: 14.6 lbs. * Dimensions: Overall Diameter: 12", Cutout Diameter: 11", Mounting Depth: 5-1/4", Magnet Diameter: 5-3/4".
RM SOLD SOLD ( with custom made SOLID rubber wood box), firm on price.
SMS/ Whatsapp/ Call
013-3955166
Finishing Silver
SMS/ Whatsapp/ Call
013-3955166
