Item(s):PHOENIX GOLD X200.4 AND PHOENIX GOLD X100.4
Package includes:AMPLIFIER, MANUAL, BOX, CERTIFICATE
Price:PHOENIX GOLD X200.4 (200x4@4ohm[underated])= rm2200nego(left 1pcs)
PHOENIX GOLD X100.4 (100x4@4ohm[underated])= RM1100(sold)
Warranty:1 MONTH
Dealing method:COD / POS
Location of seller:CHERAS KL
Contact method/details:0196888070 / 0125300509
Age of item:BRAND NEW
Item(s) conditions:10/10
spec:
PHOENIX GOLD X200.4
800 Watt Power Amplifier
High efficiency (greater than 80%)
Xe.load™: optimized for any impedance load
Xe.tune™: 24dB Linkwitz-Riley subsonic and low pass crossovers
Xe.flow™: variable thermal feedback controlled fans
Tried and true triple Darlington output stage
Buffered RCA full range thru output
Remote Monitoring Display (RMD) port
Low Pass Level control ready (LPL-44)
200W x 4 (4-1 ohm stereo)
400W x 2 (8-2 ohm bridged)
Built-in Crossovers
Optional Remote Voltage Display
Optional Remote Low-Pass Level Control
Variable input sensitivty
0 - 18dB Bass Boost at 45Hz
CEA-2006 Compliant
Dimensions: 22" L x 10.6" W x 2.5" H
PHOENIX GOLD X100.4
RMS Power @ 4 Ohms: 100W x 4 @ 14.4V
Bridged RMS Power @ 4 Ohms: 200W x 2 @ 14.4V
Signal to Noise Ratio: > 100 dB
Bass Boost: 0 - 18 dB
XeTUNE- Advanced input and signal processing circuitry
Top-Mounted Controls
24 dB / Octave Crossover
Twin-T Variable 0 - 18 dB Bass Boost at 45 Hz
Auxiliary Outputs Route Full Range Signals
Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
XeFlow- Thermal feedback system with output optimization
Bottom-Mounted Extruded Aluminum Heatsink
Expanded Metal Mesh Intake & Exhaust Vents
Ultra-Quiet Variable Speed Fan
Temperature Monitoring with Automatic Output Optimization
Superbrite 5mm LED Power Indicator
XeLOAD- Full power with automatic load sensing
Load Sensing Optimizes Power Supply and Output Stage
Maximum Power Output From 1 - 4 Ohms Stereo or 2 - 8 Ohms Bridged
High-Current Triple Darlington Output Stage
150-Volt, 15-Amp, 60 Mhz Sanken Output Transistors
Direct Insert Speaker Terminals Accept Up To 8 Gauge Wire
4 Gauge Power Terminals with Removable Rubber Grommets
Dimensions: 18.25 W x 10.6 L x 2.5 H
