More Volkswagen marketing genius as Amaroks topple massive chimney
Dinesh
770
1,700
1,593
More Volkswagen marketing genius as Amaroks topple massive chimney w/video
Wrecking balls are the weapon of choice when it comes to bringing massive structures to their feet, being able to reduce buildings to rubble with mere swings. Nonetheless, they don’t usually come cheap and aren’t exactly easy to maneuver or transport to the site.
So a demolition crew in the UK needed to bring down a 154-ton chimney, Volkswagen stepped up and offered four of their Amarok pick up-trucks to haul down the 67-meter structure smoke stack.
Before the trucks had their go though, some engineers were called upon to weaken the structure’s integrity at key points to make the task easier a little. This is standard routine for all pull-down style demolitions as the vehicle pulling wouldn’t be capable of it otherwise.
After that, the four Amaroks were hooked up with 200-meter long ropes each to the roof of the chimney. The flag was dropped and all the trucks grunted their turbodiesel mills to topple the puffer.
The bigger they are the harder they fall, and fall the chimney did at the tow hooks of the four Amaroks. Not only does this marketing exercise prove the Amarok’s towing capacity, it also provides for publicity that no other advertisement could.
There's no news on the availability of the Amarok on our shores but if it could be priced right, it would be good to have a European pick-up to give the Japanese and American trucks a run for their money.
Video Link
Source: Autoblog
The Marketplace Top Posts
True High Low Soft Hard Explained
The article is given the "thumbs up" by the famous Toyota Modification Master Bill Sherwood of www.billzilla.org/carindex.htm
See his reply to the article here http://forums.club4ag.com/topic.asp?TOPIC_ID=64777
See also contradictions by other people. It is up to the reader to believe whoever they choose :)...
