mod in 1.6 soch..ned HELP!!!
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
matpseed reprofilled camshaft
Got money? Custom everything. :biggrin:
Custom block
Custom pistons
Custom conrod
Custom valves and springs
Custom headjob (PNP)
Custom drive shaft
Custom antiroll bar
Custom lower arms
Custom Titanium Exhaust
External oil sump
External water pump
Upgraded fuel pump
1000cc fuel injectors
Microtek/Haltech ECU
FIA Rollcage
Stripped interior
Mickey Thompson Slicks
6pot Wilwood front 4pot Wilwood rear calipers
Cross drilled, ventilated, slotted Brembo rotors
:biggrin:
What else ah?
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
1.bosch fusion plugs
2.bosch supersport cables
3.exedy 3 or 4 puck clutch plate with lightened flywheel
4. adjustable crank pulley, cam pulley & high cam
5.oversized throttle body
6.K&N open pod air filter
7.
watrul3s
87
Pulau Pinang
how much for bosch supersport cable?will ngk(blue) better???
wat profil n brand cam recommended?
wat car or size of throttlebody?
calvin9683
1,768
171
3,163
JB
Perhaps the 1st thing is to make sure ur engine is healthy enough for the mods u r planning to do.....
160-180hp on a 4G92 SOHC n/a.... Hmm....
watrul3s
87
Pulau Pinang
oo..if got parts ned to change then direct change performance parts..XD
160 hp on 1.6soch izit hard to get??
Veloc
3,234
991
Sabah
Haha... For 4G92P I think if you want 100hp/Litre, BOT is the only way I guess? At least a cost effective one. All the mods sifus mention above such as cable, plugs, air filter are very good but it cannot yield 100hp/L. Or if you want to go N/A, I've seen people sell performance camshaft for 4G92P in mudah. Around 500 i think....
watrul3s
87
Pulau Pinang
i stil new in mod, mayb ply wit N/A 1st is better ..
wat kind of camshaft??jasma?piper? or matspeed?
Veloc
3,234
991
Sabah
Nono... I think just a taiwan brand or something. GO check it out la... I saw at mudah... Don't know if still have...
The 2009 Ferrari F70
In 1995 Ferrari launched the F50. Seven years after that it was replaced by the Enzo. And now, according to a rule that Ferrari always follow they will launch the F70, seven years after the launch of the Enzo. Also there are no big competitions for the F70 yet, but after Ferrari will launch this supercar on the market for sure many auto-makers will try to build competitors for it.
The Ferrari...
