MIVEC + 1.8block Overall height?
WiraLoh
I have one converted MIVEC + 1.8 block,
Recently i notice alot of car magazine also feature the same modification but their engine is not high and no need to jack up the front hood and still can use back the original extractor cover.
I have ask my mekanik he said all modified mivec with 1.8 block will be slightly higher because of the longer 1.8 block so need to jack up the front hood.
My question is
Is it possible to make it so that the mivec + 1.8block is not that high and how they do it?
I recently had to cut a piece of my hood away because my timing belt cover kept hitting the hood until it cracked.
Not sure whether you can get the block to sit lower in the engine bay but for me its higher than when i had a normal 4g93p engine without the mivec heads.
mivec head is 2 layer head, so it will higher than normal engine head.
i already modified my 4G93T with mivec head, my bonet it's okey.. not too high but still slightly higher than GSR head. i don't know how u converted u'rs..
id like to see your engine bay
hope you dont mind to share with us here
Agreed,same like my fren's,need to cut some of hood's casis/tulang. But got somebody said that the 4g93 carb's block higher than injction one, is it true??
This is the image, the makanik told me its a GSR blok, but i never ask if its a injection or a carb engine block.
So is the carb block higher than injection block?
http://img295.imageshack.us/img295/6012/03yz9.jpg
what engine is it?
4G91 OR 4G93?
is it transplant use a mivec head?
Did you raise your bonet slightly to accommodate for the heat expenditure 'cos if you did then its no wonder why you don't have any problems heh.
Its a 1.6 Mivec just change the block to a 1.8 GSR block, so all wiring still use back.
The hood has been raise up and also need to knock on the casis/tulang.
for your info,
my car almost standard modified, my bonet standard position not raise it..
just new touch.. still in progress to upgrade more..
my pocket money don't allow me to totally upgrade..
but coming soon.. hopefully...
here attach my 4G93T with mivec head pict...
i'm just new in this car modification..
slowly2 to learn it more...
especially to know more about my car..
http://img405.imageshack.us/img405/3553/mygsrqh1.jpg
of course it is mivec head..
why?... look different ek?...
actually i bought the head without it's cover..
so it seem to be different...
but it is same just without it's cover...
don't believe it?...
believed it.....
:regular_smile:
hey bro,
like this u are using wht ecu for ur monster? can share some info ah? pm me also no problem..
gsr + mivec head very powerful one oh!!!
actually i used my GSR ECU but i got some electronic tool/equipment from my
mechanic to setting my mivec opening.
i forgot what they call that thing...
maybe i msg u later for details..
right now i'm searching evo wiring complete set if any and with good price..
i want to upgrade some more..
any idea?..
