mivec 1.8 4 throttle OR mivec 1.8 with 82mm piston
MaNofWaR
570
On the AiR
4 throttle requires lotsa other things to consider...itb setup, engine management, tuning etc. do it wrong and u'll just burn a hole in ur pocket. piston upgrade will not cost u major setup mods and $$$. generally u can opt for bigger intake manifold (skunk2 or custom) with s90 tb to match which is the most popular choice
just my 2 cents
joe_mirage
1,030
44
1,648
rotationperminute.blogspot.com
i agree with manofwar. in order to use itb setup on your mivec, i recommend you to upgrade your engine internal first. It is because itb setup requires high duration & lift cam + compression to make power.
Center Hole Filler/cone/ring-Minor or micro problem? Gimmick?
Here goes,
Last Saturday I went off to Klang (kedai papan, I normally frequented other shop btw) to get myself some used Jap wheels for me and a friend.
I've known the usual tricks of replacing valves, etc that will imposed/mentioned so I could get away with it. But there is another new thing (for me that is) that the shop insisted me to use it which I obviously refused to do so. They eventually has persuaded my friend...
