Mitsubishi evolution 7
satria81
813
18
5,018
PETALING JAYA
Dear Sifu's,
I require some information:
Would it cause any sort of problems if I jump-start my EVO7 ? Will it effect the ECU or any components of the car.
Please feel free to share thoughts in this regard.
Thanks upfront.
AlucarD
1,079
115
5,163
No issues, just jump start properly. Follow the proper steps and you'll be fine
satria81
813
18
5,018
PETALING JAYA
Thanks AlucarD,
Would you please enlighten; " just jump start properly. Follow the proper steps and you'll be fine "
please bare with my noob-ness with this.
aniki
132
24
Minokamo, Japan
aniki1984.multiply.com
the jump start cable will be red n black in colour, u need another car/battery to jump start your car.
Start the engine of opponent's car. (make sure the opponent's car battery is working good)
1) put the one side head of black cable at the opponent's car battery at minus terminal.
2) put another side head of black cable at your car's battery minus terminal.
3) put the one side head of red cable at the opponent's car battery at positive terminal.
4) put another side head of red cable at your car's battery positive terminal.
And then, crank/start your engine. IF your engine won't start, just let the battery charging from opponent's car. You may go have a tea break. After 10minutes, return to your car and crank/start your engine.
IF you still can't start your engine, buy a new battery and replace it.
P/S: if you needed to jump start your engine, your battery life is almost at the end. It's time to change..lolz..
satria81
813
18
5,018
PETALING JAYA
Hello aniki,
Many thanks for the in-detail reply. Truly appreciate it.
My concern was mainly if jump-start would cause any impact on the ECU and etc etc..
p3jal
1,493
183
Selangor
wont bro.. wont effect ecu and etc
aniki
132
24
Minokamo, Japan
Yup. won't cause any effect on ecu.
I'm using Jap version of E7. The monitor will pop up a setup screen every time after changing battery or unplug battery.
Just set it back to E7, and that's all.
But, i believe most of the cars here already took/exchanged to US spec..n the steps i mentioned above was skipped..
PabloIceman
3,083
291
1,683
I had to jump start my car many times in the past due to grounding of wiring .. Finally located the problem of the ECU cable to firing cable passing through the fire-wall which was grounding.
No issues to the ECU .. which has it's own internal battery btw for the electronics ..
The Marketplace Top Posts
It’s all about the upcoming Hari Raya festivities and NAZA Quest, the official distributor of Chevrolet vehicles here in Malaysia has just provided a series of discounts and even a complimentary car for your convenience – all for the sake of ensuring that you’ve got yourself a Chevrolet that’s in good working condition for that long-haul back to visit the relatives...
