Mitsubishi’s Animal : Concept-RA
MeraBoy
590
Just one word.... WOW ! Is Mitsubishi back on track to make us an amazing sport car a bit like in the past with the Twin Turbo ? The Concept-RA certainly looks like an artist’s interpretation of a new Eclipse, although the front and rear fascias also share the new Lancer Evolution design language. But this is no Eclipse - in fact it’s anything but a front-drive petrol car with more show than go. This is a new animal altogether.
Tokyo, November 27, 2007 — Mitsubishi Motors Corporation (MMC) and Mitsubishi Motors North America Inc. (MMNA, based in Cypress California) will premiere MITSUBISHI Concept-RA to the world at the 2008 North American International Auto Show (NAIAS or the Detroit Motor Show). MITSUBISHI Concept-RA fuses a passion for dynamic, exciting driving with a heightened sensitivity for the environment thanks to clean, efficient high performance diesel power. The 2008 NAIAS runs from January 13 to 27 at the Cobo Center in Detroit and opens to the general public on January 19.
MITSUBISHI Concept-RA shows that thrilling performance and environmental responsibility need not be mutually exclusive concepts. This coupe concept features the Super All Wheel Control (S-AWC) vehicle dynamics control system driveline and the Twin Clutch SST automated manual transmission used in Lancer Evolution*1, is powered by a new high-output, high-efficiency clean diesel engine.
The MITSUBISHI Concept-RA S-AWC driveline adds Active Steering and Active Damping control to the ACD*2, AYC*3, Sport ABS*4 and ASC*5 component systems that comprise the system used on Lancer Evolution. S-AWC integrally manages all of these systems to realize advanced levels of control over drive torque and braking, thereby upgrading traction, cornering and vehicle stability. All this adds up to intuitive, on-demand vehicle behavior that faithfully reflects driver intent under all driving conditions, from everyday use to emergency avoidance situations.
MITSUBISHI Concept-RA is powered by a new high-efficiency, low-emissions 2.2-liter 4-cylinder DOHC 16-valve turbodiesel engine with MIVEC*6 continuously variable valve timing control. With piezoelectric injector common-rail direct fuel injection that allows a lower compression ratio and with a VD (Variable Diffuser)/VG (Variable Geometry) turbocharger, the clean diesel unit delivers a maximum output of 150 kW (204 PS) and maximum torque of 420 Nm (42.8 kg-m). For compliance with U.S. emissions standards (Tier 2 Bin 5 emission regulations), the engine relies on a new catalytic converter system that brings together diesel oxidation catalyst (DOC), NOx trap catalyst (NTC) and diesel particulate filter (DPF) technologies. The new diesel engine will deliver exciting driving manners with a high degree of fuel efficiency.
For improved crashworthiness and to reduce vehicle weight MITSUBISHI Concept-RA features a new body structure using an aluminum space frame made from extruded aluminum sections and die-cast aluminum members, as well as engine hood, fenders and other outer panels made from high impact-resistance and easily recyclable plastic resin.
*1: Lancer Evolution X in Japan
*2: Active Center Differential
*3: Active Yaw Control
*4: Sport Antilock Brake System
*5: Active Stability Control
*6: Mitsubishi Innovative Valve timing Electronic Control system
Source:
"MITSUBISHI Concept-RA"
rusifiz
193
kl-sban
www.fgsn9.com
artist's impression of the gen2 ,looks great years ago.. but the end result was disappointing..
let see what the Mitsubishi's engineers have, to create a real thing out of this bizarre artist's impression... ^_^
1.use ruler to mansure 3 Ager plus 1 mansurement for the top to close up the cai to mean " LJ " <----this 3 angle,the mansurement for the top is just to close connected/close the 3 pcs of alcalic
2.go to advertising shop buy 4pcs of transparent Alcalic
.3for making the shield
.1for the top
how to stick up the alcalic togather?
just easy put the alcalic as "LJ" ship that you need apply coloform on every corner then it will stick up,more information about conneted the alcalic can ask...
