Mini Clubman 4 sale
Mini Clubman 4 sale
bgr5777
21
Hello people, i have a mini 4 sale, specifications as listed below. Don't want to sell it but i need a normal car and can't afford to maintain and store 2 cars. Am asking for RM18,000 but am open to offers...
Please mail me at [email protected] if u r interested, thanks 4 ur time...
Chassis:
1972 Mini Clubman bodyshell (white exterior, red interior)
Multipoint rollcage extended to front and rear subframe mountings, fabricated by TVR Malaysia
Fabricated tubular floor section, flat alumimium sheet floor sections.
Solid mounted front subframe
Standard top and lower arms
Adjustable castor rods
Polyurethane mounted rear subframe (to rollcage)
Standard radius arms
Dampers: F: Spax Adjustables (w 2 spares)
R: Spax Adjustables
Engine: Built by Axis Garage
Rosejoint/solid mounted to front subframe/front bulkhead
A-series 1300GT block overbored to 74mm
ART-Mazda 808-model dome-top pistons
RIK piston rings
Modified factory con-rods (A+)
Factory crankshaft (CAM6232)
4-bolt billet steel centre main strap
Vandervell main bearings
Glacier con-rod bearings
ACL camshaft bearings
Kent Megadyne 315° camshaft
Kent Cams vernier duplex cam pulley
Stage 4 cylinder head
Iskendarian double valve springs
Iskendarian alloy valve spring caps
Factory pushrods
Factory lifters
Factory 1.3 ratio rockers
Payen Metro Turbo metal head gasket
FAI Sureflow oil pump (C-AEG411)
Motul 2000 20W50 engine oil
Factory Unipart water pump
Alloy rocker cover
Lightweight NipponDenso alternator
Air-con compressor
Factory remote-gearshift gearbox
Minispares centre oil pickup pipe
3.44 final drive
Minispares Ultralight flywheel
Minispares backing plate
AP road rally clutch diaphragm
AP road clutch plate
BEHR E36 325i radiator
Slim profile radiator fan
Custom fabricated cooling system plumbing
Thermostat blanking sleeve
Mitsubishi oil cooler
Custom-made remote-oil filter housing
Threaded oilway plugs.
Weber 45 DCOE
K&N 4” air filter
Minispares 6” alloy manifold with linkages
Shimano Teflon throttle cable
Mitsubishi fuel pump
2” LCB exhaust manifold,
2” exhaust system: center box, rear silencer
NGK BP6ES/BP8ES sparkplugs
Lucas ignition cables
Lucas Sport ignition coil
Factory distributor, vacuum advance disabled
Interior:
Bride driver & passenger seats
Willans harnesses
Personal steering wheel
Custom fabricated alloy/polyproplene rearbulkhead
Custom wiring
Water temp gauge
Oil pressure gauge
Manifold Vacuum gauge
Fuel level gauge
Tachometer
AutoGage by Autometer 5” Monster Tach with shiftlite & memory recall (to be replaced with another tacho)
Nordskog A/F ratio gauge with sensor
Sparco cut-off switch
Fuel and brake lines routed through interior
SCG NS40 battery in rear section, battery cable routed through interior
Factory brake/clutch pedal box
Brakes:
Factory AP servo & master cylinder
Metro AP 4-piston calipers
Custom fabricated spacers (steel)
DBA 260mm front rotors, cross-drilled & slotted
Custom fabricated hats (steel)
AP Lockheed front pads
Factory rear drum brakes
Motul RBF600 brake fluid- brakes and clutch
Exterior:
Front laminated glass windscreen
Side and rear screens, acrylic
Group 5 arches (missing front left arch)
Yamaha side mirrors
All steel panels, lightened, fully detachable
Hella H4 halogen headlights
Daihatsu Mira fuel tank, Yamaha fuel filler
Wheels:
JRD Rial Star 13x7 wheels
Fulda Assuro 175/50-13 tyres
Weight: 650kg (w/o driver)
bgr5777
21
thanks for ur support,
sorry, i got no pics, no digicam, maybe later...
fastclubman
469
driven it and been in it....its awesomely fast. Puts many newer powerful cars to shame, and this is in straight line. Handling and roadholding is INCREDIBLE!
Good buy as Owner takes care of the car very very well!
fastclubman......
bgr5777
21
don't say until like that-lah, hehe.
will be doing your cf dash tomorrow... should be looking killer
thanks,
bgr
bgr5777
21
erix7: i finally got some pics courtesy of a friend, they are a bit dated though, before the arches, dash and other stuff were fitted.
oldcar: the car is in KL/Selangor area
shaune
59
15
3,008
nice ride... i interested..can pm me your address so that can view the car??
sms me also can 019-338 9659
thanks..
bgr5777
21
hi shaune,
sorry, car just sold...
thanks anyway.
bgr
Hey members,
I am a Malaysian. I used to be a student in USA and now I have graduated with a Master degree. I have then work here for more than a year. I own a car in here for almost 3 years and I would like to import it back to Malaysia. My car is a LHD car. 2008 Mitsubishi Lancer Evolution X. Anyone know the procedure to import it back to Malaysia? Also register to drive on the road. The cost, etc?
Please help! Thanks a lot.
