mazda b8 turbo matters
siput_turbo400
18
terengganu
greetings otai2 and sifus...
i just wan to share my b8 probs..
after i use haltech e6x ecu on my b8 turbo engine,2 cylinders running rich 2 cylinders running lean.
i already replace many parts such as plugs,coil,alternator,plug cable,injectors but the problem still occurs.. please sifus.. help me..
xtremeleo
3,247
464
5,183
have u recheck the wiring of the haltech unit? i suspect either the ecu or wiring sir
siput_turbo400
18
terengganu
already check the wiring... all seems ok.. could it be the fuel setting of the ecu itself? anyone? i'm not sure wether e6x can control the fuel setting for each of the injectors or not.. if can,how to set the fuel setting for each of the injector? haltech sifu... please help..
xtremeleo
3,247
464
5,183
ive never heard of such a thing, but is possible, although i cannot see why its needed.. i ran across a problem wit the injectors' timer circuit not so long ago sir, have u checked dat yet sir? try to change to another ecu unit and see what happens sir
I`m a mechanic myself. but this Renault Kangoo is givin me headache! Cold start,ok! But when it has done 5 to 10km, it will suddenly dies off! I had top-overhaul the engine, T.belt replaced, coil replaced,CPU re-set,battery replaced. The temp. gauge shows fine at optimum. At times it will jerks when accelerate. An original fuel pump was also placed. pls help.
